My Whirlpool WDT720PADM dishwasher stopped functioning properly last night. It will run through a full cycle, filling, draining, heating, soap door opens and steam vent opens at the end. While running, the main pump never sprays water or makes noise. I hear a relay click when it should come on, but it does not. It does not hum, just does nothing. I ran the diagnostic check on the machine and no new fault codes have been recorded. The dishwasher's processor thinks all is good. I also left the breaker off all night thinking perhaps something would reset by the morning. No good.
So, I opened the cover and tested the main motor's fuse through some pins on the board, it had proper continuity and negligible resistance. I tested resistance through the main motor through the two large blue wires running to it and it registered between 11 and 12 Ohms. I also found no continuity from either motor lead to ground. Finally I gave the motor 120 volts AC through the two large blue leads, flipped to try both polarities and got no movement or noise.
I am not able to test directly against the motor so there could be other smaller wires going into it that I do not know about that could have an impact. I also tested resistance on an old, known working, dishwasher pump motor and got around 11 Ohms, so I figure that number was reliable. I was almost ready to call it a day and order a new motor assembly, but ran one other test with the dishwasher running and at a cycle where the motor should have been running. There was no voltage across the two blue wires that run to the motor and I expected there to be. Now I am confused.
Are there better ways of isolating the problem without taking the pump out of the machine? That is the next step I think, but I would like to avoid it if possible.
In the image below, two green lines point at the two blue wires I have been testing the motor with. One looks red; it is blue with a red stripe. Other is blue with a white stripe. They are next to the hot and neutral lines from the wall.
Control Board in Dishwasher
  • I have begun dismantling the sump. Noticed that the two big blue wires are for the heating element not the main pump motor. So, the confusing bit makes sense now.
    – zerpsed
    Dec 26, 2016 at 15:40
    OK, 25,000,000 OHMs through the motor lol. Guess it's shot.
    – zerpsed
    Dec 26, 2016 at 15:53
    Just came across your post because my whirlpool dishwasher decided to crap out this morning. Here's what I did. First there's an awesome video on YouTube walking you through all the steps to remove motor unit. I took it out, removed the motor from the whole unit and took that apart. Cleaned it up (so much gunk!) Put everything back to together, checked all electrical connections, and the thing worked!!! Just saved myself about $400 in service and parts! Jul 25, 2020 at 17:17
Test the main pump motor using the proper wires. The largest wires, other than the AC from the house circuit, feed the heating element. Those would be the two large blue ones indicated in the question's image. Heating devices generally draw the highest current. The main pump motors leads come off the board to the right of the AC in lines. They are a dull blue color and easily visible in the questions image. There should be continuity through the wires with very little resistance. There should be no continuity through either wire and ground. This setup is very likely the exact same for many different Whirlpool dishwashers.
    I thought about deleting my question since I was testing the wrong wires and had made poor assumptions. Instead, I decided to answer it because if I had come across this question with this answer when searching for help, I would have saved myself a lot of time and had a new motor in the mail sooner. Hopefully this will save someone else some time.
    – zerpsed
    Dec 26, 2016 at 17:24
  • Replacing the main pump motor took care of my problem. For my dishwasher, I used this part: Circulation Pump W11032770 from the Repair Clinic. repairclinic.com/PartDetail/Circulation-Pump/4455920
    – zerpsed
    May 29, 2018 at 18:58
  • I also found that the pump motor itself is probably ok. It has a board on top of it that likely went bad. After swapping with the new pump/motor, I vaguely recall ripping off the board, applying 125V directly to the "bad" motor and it spinning.
    – zerpsed
    May 29, 2018 at 19:01
