I have four lights altogether in two rooms that I want to power with one service. Each room has a SPST switch that will turn on two lighting fixtures in that room. I want to be able to turn the lights on in each room without having to worry if the other switch in the other room is on or not, so I do NOT want a three way switch setup.
I am also concerned with having to wire grounds in all my resistors as well. Do I need to, or is just wiring lead/neutrals going to work? I did not think it was necessary so my diagram does not have grounds included. However, my Romex is 14/2, so if I have to, the option is there.
I have been researching many videos/tutorials for this schematic, but can not find any that match what I am trying to do. I have also looked for some related answers here on Electrical Engineering, but could not find any that match. From what I know about parallel wiring, I believe I have this schematic correct, but I just need to make sure. Measure twice, cut once.
Schematic Schematic two, with ground
    You mentioned "resistors" in your question and comment. I assume you're not actually using resistors in your circuit, but are talking about the light fixtures? – Ken Shirriff Dec 23 '16 at 21:22
Yes, your diagram is correct. It will achieve what you described.
You should always connect the ground, it is a safety measure. While it may not appear to do anything during normal operation, it's presence covers many failure cases that have been discovered the hard way - death by electrocution, house burning down, etc.
You should also absolutely check your local electrical codes and regulations for how to correctly do an installation, there are many things that are not obvious or intuitive. In the USA, "NFPA 70" is the name of the code book. There are also many laws that cover who is allowed to do this kind of work, inspections, and etc.
| improve this answer | |
  • Thank you I have already read my local building/electrical codes and have already received my permit to this work. – Xavier Dec 23 '16 at 19:59
  • As a safety measure I will redraw my diagram to include grounds. – Xavier Dec 23 '16 at 20:00
  • That probably would have got me a fail during inspection. haha – Xavier Dec 23 '16 at 20:00
  • As far as my grounds are concerned. I imagine just splitting my grounds to the two rooms will do? – Xavier Dec 23 '16 at 20:01
  • I imagine I will have to "pig tail" with wire nuts at each resistor? – Xavier Dec 23 '16 at 20:04
