I search in google about how to shut off the water valve under the sink. And it say "turn counter-clockwise until it tight" and I did, but the water still running.
    Did you see any influence at all on the water flow? Do you have two valves (cold/hot)? – Jasper Dec 23 '16 at 8:03
Remember "Lefty loosey righty tighty". Turn the valve Clockwise (right) to close and counter clockwise (left) to open.
  • I did that but the water still running – Chitlay Mariame Dec 23 '16 at 2:23
There are a few possible situations.
  • The valve stem has fractured, in this case you can turn the handle endlessly in either direction without any effect on flow and without ever reaching a point where the handle won't turn any further. Normally a handle would turn no more than three or four revolutions in each direction - fewer for some types of valve (tip - add a photo to the question)
  • You didn't turn it far enough. Sometimes valves get stiff. You might think it reached the end of its travel before it has.
  • You turned it the wrong way. Try both directions and carefully monitor rate of flow from the faucet.
  • Wrong valve.
  • The valve is the main stopcock for the building but water can back flow to the kitchen faucet from pipework in the rest of the building - particularly from upper floors. Check for other valves, especially if you have header tanks. wait 5 to 10 minutes after turning the valve fully in one direction to see if flow rate is slowing.
