I'm running multiple wires through the same PVC conduit pipe (1.5") that need to exit into flexible liquid tight that is (0.5"). I'm not seeing any reducers for doing something like this other than white plumbing connectors.
Here is the "T" I was planning on using:
Here is the liquid tight:
Can this be done up to code? What are my alternatives if it cant?
