I am experiencing an electrical issue with my 200 amp 42 space Eaton panel. There seem to be 7 random "dead spaces" where no power is being supplied to the breaker resulting in dead circuits. I have eliminated bad breakers or faulty wiring. Replaced old breakers with known working breakers, still nothing. Swapped circuits (breakers stay in place, only swapping hot wire) and still no power from the dead space, but previously dead circuit now functional showing 124 volts connected to a different breaker in a different space.
These 7 "dead space" show between 6-7 volts when breaker is flipped on and nothing when breaker is off.
Did not detect any open grounds or neutrals.
I do not believe I have lost a leg as the "dead spaces" are random and not isolated to one side.
No physical damage observed to hot bus bar.
Anyone have any ideas? This ones got me stumped!
