In my apartment my bathroom light and fan comes on at the same time. Is that standard for an apartment?
  • Where are you on this planet? – ThreePhaseEel Dec 18 '16 at 16:10
    That's very common, at least in the Americas. It's also the cheapest and easiest way, as a lot of (older) buildins don't have wiring for separate circuits for a fan and light. – Brock Adams Dec 18 '16 at 20:18
  • I joined this site just to upvote this question. I've wondered for a long time why people do this. – Ari Brodsky Dec 18 '16 at 20:38
9
Many apartment owners wire the fan and light to a single switch. The reason I have done it is to limit moisture build up. Not all renters are responsible enough to turn on the fan while using the shower. Failing to do so can cause moisture to build up and allow mold to form.
| improve this answer | |
  • Yes, but along those lines, the fan usually needs to run for many minutes after the room is unoccupied to remove moisture. But it can't because the light was switched off when the resident left. This is why draconian states, like California, now require either automatic, or always-on, fans. – Brock Adams Dec 18 '16 at 20:20
  • @BrockAdams There exist fans which you connect four wires to: ground, neutral, phase for power, phase from light. Such a fan will turn on when the light is turned on and keep running for a certain number of minutes after the light is turned off. – kasperd Dec 18 '16 at 21:46
  • Most hotels have something similar, which means you either freeze in the shower or shower in the dark. – Milliways Dec 19 '16 at 0:43
