I am replacing my old halogen under-cabinet lighting with LED lighting. I removed the old lights, but the access plates on the new lights are in different places. The issue is that if I run the existing, unsheathed wires to the new access plates, there would be unsheathed wiring under the cabinet between the point where the sheathing was originally removed and the new access plates. There are two separate wirings for most lights since they are chained together.
What solutions are there, short of opening up the walls and actually replacing the entire run of cable? I considered cutting most of the unsheathed portion off and adding two low-profile junction boxes, if such things exist, but I think they'd be visible and not too attractive.
