NEC 240.24 requires overcurrent devices (fuses/breakers, incl. AFCI/GFCI/DFCI breakers) to be placed so that their operating means is no more than 6'7" off the ground under most circumstances, and also imposes a few other requirements on their placement (not near easily ignitable materials, not in a dwelling unit bathroom, not over a staircase). However, it seems there is nothing in the NEC that governs the placement of receptacle-type or deadfront circuit interrupter devices, or whether their operating means must be accessible whatsoever -- apparently, even boneheadedness like wanting to put a GFCI in one's ceiling is Code-compliant.
Am I correct that there are no placement requirements for deadfront or receptacle type circuit interrupter devices? (i.e. GFCI receptacles can be placed over stairs, in a ceiling, 20' up on the wall, in a clothes closet, or in a dwelling unit bathroom, the last one being quite common practice in residential wiring.) Or am I missing some part of the Code that prohibits such boneheadedness as a GFCI receptacle that's too high up for anyone to reach, or a deadfront AFCI in the back of one's clothes closet?
If this is allowed by code, what risk would an interrupter device in a bathroom or closet or over a staircase pose, compared to that posed by a singular overcurrent device in that location?
