Let me start off with a diagram
This is the projector screen in front of the wall. The vertical bars are the studs.
- There are probably 4 or 5 more studs between the edges of the screen).
- The frame of the projector has about a 3" gap from where the keyhole slots or loops for hanging are located.
I'm trying to figure out how I can attach the projector screen to the wall or the ceiling. I don't seem to be able to attach it to the wall because of the positions of the studs. I would only be able to attach to one of the studs with brackets or a screw.
I would prefer to hang the projector from the ceiling, but the joists run parallel to the wall, so the nearest one is 18" from the wall, which is much too far for where I'd like the screen to hang.
