This answer indicates that the water pipes should bonded to the electrical ground even if a grounding rod is used. How would one normally tell if that is the case? Is that bonding required to be accessible, or can it be hidden behind walls or buried? Where in the water system would it normally be bonded (e.g., before the main water shutoff, after, at the hot water tank)?
I recently had my electrical panel relocated and replaced, and don't recall seeing anything running from the panel to a water pipe - in the old panel or new. The electrician put in an intersystem bonding bridge, so the new ground rod, ground from the panel, and ground from the cable service are connected to it. I suppose that's where the bond from the water pipe would go?
