I replaced my dishwasher a few days ago. The old one didn't need / use a ground, but the new one does. The old one was coming through a junction box that then went along to a dimmer switch, with 3 wires running to it. I measured with my MM hot - neutral and got 120, then hot to third wire and got 120, then again neutral to third wire and got 0 also. I assumed that that was the ground wire and spliced in a wire at that junction running it to the ground wire of the dishwasher.
Dishwasher works fine now. However, when I turn on the dimmer switch, there's an audible buzzing sound and the lights don't come on. The dishwasher continues to work (or at least stay lit) with this switch on.
What did I mess up?
edit
It's possible that the cap I used to splice the ground wire in was too small for 3 wires. Would this behavior be consistent with a loose ground connection for a dimmer switch?
edit 2
- It was a loose connection. Fixed that, switch works, no buzzing. But I'm still concerned that the yellow cable coming in is not a ground.
- Measuring hot - supposed ground. Switch off - 120V. Switch on - 0V. Neutral - supposed ground. Switch off - 0V. Switch on - 120V. Is this a switched hot? This is off the old dishwasher circuit breaker. The only thing on it is the dishwasher, dimmer lights and one kitchen outlet. Why would there be a switched hot down there?
Center hole - in from the wall. White, Black and Yellow wires. Conduit to the right - goes to dimmer switch. Conduit up goes to the new dishwasher box. It looks like there are 4 wires running to the DW box, there aren't. The yellow just loops past it. I'm using a scrap of white wire for the ground (I know, I'll fix it - all I had at the time).
