My GE HE clothes washer ALWAYS has water under the tub - when you move the tub you hear it sloshing around.
Is this normal?
If not, thoughts on getting a proper draining?
Let me know, thanks!
My Sears Kenmore top loader washer machine tub has a construction where there is a donut shaped compartment built around the bottom of the tub. It has water inside of it!!
A couple of years ago when I replaced the tub bearings I was mildly surprised to note this interesting construction. It did not leak or pour out when I had removed the tub during the repair. I can only guess that the water plays a role in the dynamics of the tub motion in conjunction with baffles inside the water compartment.
So I would guess that this is normal for your GE washer tub as well.
