I bought these 3 things on Amazon:
• Leviton 8806 Bayonet Base, Keyless, HID, Glazed Porcelain Lampholder
• Fulham WH2-120-C Workhorse Adaptable Ballast
• Philips 327817 35-watt T15 SOX35 Low Pressure Sodium HID Light Bulb
I don’t know a ton about electricity or LPS bulbs but I need to safely plug this in to a regular 110V wall outlet. I’m not sure what the job of the ballast is, but I’m guessing I have to wire it into a power cable that will then plug into the wall. Am I right?
And do the 2 white cables from the Lampholder connect to the Black & White cable on the ballast?
Any help would be appreciated! Thank you!
  • Take a close-up pic of the label on the ballast, I tried to zoom it, but can't read it blown up that much.
    – Tyson
    Dec 4, 2016 at 0:53
    Also, you need an enclosure for that lamp. Do NOT burn it without, it's unsafe, if the bulb explodes you'll know why I warned you.
    – Tyson
    Dec 4, 2016 at 0:55
    Also googling the part number that ballast appears to be fluorescent. Why do you think it pairs to that lamp?
    – Tyson
    Dec 4, 2016 at 1:01
  • Thanks so much for the help Tyson, I bought that Balast because that's the one AMAZON recommended, it's model is WH2-120-C. Can you recommend an enclosure?
    – user63400
    Dec 4, 2016 at 4:28
  • 4
    Amazon recommendations are absolutely NOT about compatibility. They are used for marketing, and shows things their algorithm thinks you are most likely to buy given what it knows about you, or that their advertisers have paid them to promote. Dec 5, 2016 at 7:12
4 Answers 4
I bought the same stuff. At first it appeared to be the wrong ballast. Of course it came without any guidance.
I tried it and it does work.
Black & white wires to to 120VAC power. Red wires (2) tie together and connect to one of the lamp socket wires. Yellow wire goes to the other lamp socket wire.
When you apply power the lamp will glow immediately but not very brightly. The light will be orangeish not yellow. Let it warm up for a few minutes maybe 5-10 and it will be bright yellow like you would expect.
I have run the lamp once and it works. I cannot comment on whether it is correct or safe. The current consumption was low and everything seemed well behaved.
Proceed at your own risk.
This is a bunch of random junk.
Stop buying things this way. You can't just throw random electronic bits together and have them work. But don't feel bad, this happens a lot. We get a steady stream of people buying random dimmers and smart switches and wanting to configure them 3-way to control some cheap LEDs they got off the bottom shelf of Walmart, or other equally random things.
School up
You just need to get some magazines, good "how I built it" sites on the Internet, or whatever, and read up on how others are doing what you are trying to do. By the way, low pressure sodium is the best for some applications.
Buy used
From time to time, low-pressure sodium fixtures come up on the used market: Craigslist, eBay, etc. See what you can find. Good chance though if you are trying to do home herb farming, the best lamps may be in high demand, especially now that many states have made one particular herb legal.
-1
This ballast will run a 18W SOX bulb fantastic and would more than likely run the 35w fine also. A compact fluorescent ballast with correct wattage rating can safely run these low wattage low pressure sodium bulbs great.
-1
The WH2 ballast divides its output between the two red leads and uses the yellow as a commom. Connecting the two red leads together will deliver the full output to the lamp. The SOX-e lamps can be driven by various arc tube supplies , however since the current density of the arc and the arc voltage of LPS lamps is a narrow optimum band and is different from the design characteristics of mercury vapor HID and fluorescent tubes the light output is below the designed optimum output. When possible it is still better to drive the lamps with a lamp specific power supply. Philips - 71A0201|LPS 18W Ballast w/o the cap. $55.00 ea + $10 shipping , https://topbulb.com/philips-71a0201lps-18w-ballast , They have 3 left in stock ,
