I would like to install a projector to my living room ceiling. As the ceiling is relatively low, however, I'd like 1) to have the projector "standing" there upside down (in contrast to a mount that takes up another 20cm or so of room height). I held it there and the projection is pretty perfect this way. Heat and air circulation are not an issue. Also, 2) I'd like to use some sort of clip system to slide the projector into and out of if I don't use it. There have to be be some sort of metal plates that can be screwed onto projector and ceiling which fit snugly into each other... some help would be greatly appreciated. Thanks!
closed as off-topic by Michael Karas, Chris Cudmore, keshlam, Tester101 Dec 5 '16 at 11:51
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions seeking product or service recommendations are off-topic because they tend to become obsolete quickly. Instead, describe your situation and the specific problem you're trying to solve." – Michael Karas, Chris Cudmore, keshlam, Tester101
If this question can be reworded to fit the rules in the help center, please edit the question.
  • VTC (vote to close) because this is basically a shopping question. Now with that said maybe you want to put on your DIY had and work at crafting up your own brackets. – Michael Karas Dec 1 '16 at 15:24
  • @MichaelKaras if you can show me one single projector mount to buy like the one I want to build, I happily agree. Otherwise I'd be grateful if you could give me tips on which tools and material to use to do it myself... – wehnsdaefflae Dec 1 '16 at 16:50
  • Did you try googling a "projector low profile ceiling mount"? There are lots of options. – Samuel Dec 1 '16 at 18:48
  • @Samuel yes I did. Below the ones sold for 70$ and way above there are several suggestions to build you own. Neither the ones sold nor the DIY ones, however, are detachable... – wehnsdaefflae Dec 1 '16 at 21:09
Just use thumbscrews to attach the projector to a low profile mount, like this one. This approach allows you to maintain the positioning settings of the mount and have the projector free of mounting hardware when you detach it for use elsewhere.
Alternatively, build a small wooden box or shelf and set the projector on it when you want to use it. If you use a shelf like the one pictured below, you can use hooks instead of eye bolts for mounting so that most of the shelf can be taken down when not in use.
  • Similar to the low profile you list and show "like this one" image for, was what I was going to post. They sell on the auction site for about 13 dollars. Instead of using the side screws to hold the one section to the other one can substitute two detent pins for quick release. I basically did this for my hanging flat panel in my RV. – spicetraders Dec 1 '16 at 21:37
  • @spicetraders That's an excellent tip. Thank you. – Samuel Dec 1 '16 at 21:40
If it was me working at making a projector mount for ceiling on a DIY basis I would work out how to make an open bottom box that is up in the ceiling between the ceiling joists. Then a platform for the projector is the lower cover for the box and is designed to swing down below the ceiling level using pantograph type arms. Pull down for use and push back up into the ceiling when not in use.
Such type of thing could be trimmed out with nice looking hard wood. For those really into automation a remote control activated motor could be setup to raise and lower the projector.
Here is a random picture capture from Google image search for "hidden projector mount". There a plethora of examples. This first one looks like it may be a commercial product.
This one on the other hand looks very much DIY and was made to pull out from a soffit near the ceiling.
