ok so i am trying to figure out if my basement is pre-plumbed for a shower. the close up is the small black circle in the bottom left of the bigger-view-picture. you can see it is preplumbed for a toilet.
2That is more likely to be a sewer clean out than an a location intended for a fixture. I think the pipe is your water supply but it looks odd with a yellow handled valve.– Dan D.Nov 29, 2016 at 7:39
@dan d. The pipe is most definitely his incoming water supply. Right after the wall is the water meter.– GrantNov 30, 2016 at 23:14
Add a comment
1 Answer
it is a clear out drain i found out
1Hello. Thanks for supplying your own answer, but would you please flesh the answer out a bit (e.g. how did you find out?), and then mark it as the answer by clicking the check mark. Thanks! Dec 24, 2016 at 2:28
