How Do I hookup Honeywell RTH8500 thermostat with No C wire with wires RC, RH, G, W, Y currently used? I have an external wall adpater transformer but don't know where to connect it to. I have separate Heating and Cooling (Heating is a Weil McLain Boiler for Hot water baseboard and Hot water(no tank) and Cooling is a separate unit that was added later.)
RC Cool
RH Heat
W Heat
Y Cool
G Cool
  • What model of thermostat are you dealing with, and can you post photos of the wiring at each end? – ThreePhaseEel Nov 27 '16 at 21:48
  • Honeywell RTH8500 – ajb1974 Nov 27 '16 at 21:50
  • It does not answer the question on where or what to do with the second wire from the external transformer. – ajb1974 Nov 28 '16 at 0:29
  • @Machavity -- not a dupe -- he is using a two transformer configuration vs the normal single transformer config – ThreePhaseEel Nov 28 '16 at 1:18
  • Can you post pictures of the wiring at the boiler end? – ThreePhaseEel Nov 28 '16 at 1:18
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
