I have a heat pump system with 5 wires on the thermostat where the yellow and white are tied together (and this system has been working fine for 2+ years). Couple questions about this setup:
1) Why are the white and yellow wires tied together?
2) I'm trying to hook up a Nest (3rd gen). Its terminals only take 1 wire. Support wasn't much help and told me that my current setup is wrong and the white/yellow wires should not be tied. How do I switch to the Nest setup properly?
picture of old setup (which is working fine):
Thank you in advance for any help!
    Check the other end at the furnace, give us the names of the terminals the wires are connected to. It sounds like standard color codes where not used. – Tyson Nov 25 '16 at 20:46
  • @Tyson Thanks for the reply. I'll have to hunt down the other end and get back to you with that info. – SudoKill Nov 25 '16 at 21:10
