I am looking into drywall on the HomeDepot website and I see they have few thicknesses: 1/2", 5/8", 3/8" of the same Sheetrock brand 4'x8' Gypsum Board. What are the different use scenarios for each thickness?
Also, what are the different uses for the differnet types? For example, Gypsum, Gypsum Base, Firecode Core, UltraLight, Mold Tough, FireGuard, etc?
    Possible duplicate.
    – bib
    Nov 25, 2016 at 3:08
  • They only mention 5/8". So its not even close to be a duplicate. Nov 25, 2016 at 13:39
  • The selected answer gives the various uses for different sizes.
    – bib
    Nov 25, 2016 at 14:01
  • So you should mark the answer as a duplicate. Not the question Nov 25, 2016 at 23:25
There are two websites that go into the detail for which you're seeking: National Gypsum and Gypsum.org.
Quickly (how I spec it):
3/8" = double layer applications, non-load bearing & closet/storage/decorative applications (not intended to restrict sound or provide structural support in single layer applications)
1/2" = standard "contractor-grade" thickness for walls & ceilings (min. code in most applications)
5/8" = standard "custom-grade" (when double 3/8" isn't used)
  • I see that the price between the thicknesses is roughly $1USD on HomeDepot's website. If a 5/" drywall is better in sound proofing, why it is not the chosen "contractor-grade"? Is it because the "contractor-grade" is the minimum setting? Nov 26, 2016 at 21:06
    5/8" isn't the most widely used, perhaps, because 1) it isn't req'd to meet code, 2) it costs more (which adds up and every savings counts), 3) home buyers don't reject homes built w/ 1/2" (demand isn't impacted), 4) 5/8" does make a job go a bit slower (again, it adds up), 5) 1/2" is a "happy med." between 3/8" & 5/8", 6) 5/8" does change standard dims. of doorway thicknesses (which can require wider moldings and more trim rip cuts = +$) Nov 27, 2016 at 18:12
  1. Insulation (biggest one).
  2. soundproofing.
  3. Moisture permeability.
  4. Fire Rating
A material by material comparison would be beyond the scope of this forum.
