Trying to replace these old switches (1990 build) to new Leviton z-wave switches DZS15-1BZ.
The Leviton manual for new switches expect 3 (BL, WH and RD wires) + 1 ground. But when I opened the old switch, I see 2 BL wires and 1 ground (which is no plugged to the switch).
Now how do I figure out where these 2 BL will go in the new switch?
Old switch: old switch
New switch: new switch
You may be out of luck. Mechanical switches don't need a neutral. Electronic gizmos generally do.
  • The black wire that is permanently hot connects to BK
  • The black wire that is switched hot (goes to load e.g. lamp) connects to RD
  • The white wire that is missing Connor spotted connects to WH
  • Nothing connects to YL/RD (that is only for 3-way switches).
  • A pigtail from the ground wire connects to the green terminal screw.
Worst case: You might need to run new wiring to the switches. That might mean opening up the walls.
  • What is the advantage of this new type of switch that requires new wiring? Are the old type still made? Nov 24 '16 at 11:38
  • @Jim. The "advantage" is you can (boast to visitors that you can) turn your lights off in your home while you are eating sushi with the pope in Tokyo at 4 a.m. Yes the old type are still made (mostly badly, in China). I once felt the same way about TV remotes. Nov 24 '16 at 11:42
  • My junction boxes have a lot of the room taken up with pigtail connections to the original 1970 aluminum wiring. I don't think they will accommodate any of these new devices. I saved the original 3-way switches controlling one outside light when I put a timer on it 30 years ago. Now I want to return it to original and have the switches I took out. Nov 24 '16 at 12:48
  • From the first picture, you can see a neutral in the box, so the wiring should be sufficient. Box fill may be another story however @RedGrittyBrick Nov 24 '16 at 13:51
  • You can buy quality switches, you just have to pay $3-6 for them instead of 74 cents. Electronic switches are a godsend for "making safe" many unsafe situations and otherwise-unsolvable wiring problems. Nov 25 '16 at 0:56
