How do I go about changing this lightbulb? The frame won't come out and there's no spring to pop out the bulb? Any and all help is greatly aplreciated!
    Does the outer ring (black) pop off if tugged on a bit?
    – wallyk
    Nov 23 '16 at 23:48
You have to pull the outer potlight trim frame straight down and out of the ceiling. Then you will be able to access the bulb from the back side.
