I am installing a new over-range microwave in my kitchen and would like to vent to the outside rather than recirculate. It will be mounted to an interior wall, so I either have to go up or down. There's a second floor above me and a basement below me, so I want to go down through the basement.
Do you see any problem with installing a rectangular stack duct pipe in the wall behind the range and venting through it? I'm not sure how to make the initial connection from the microwave to the stack. Does anyone have any suggestions or warnings?
  • Do you know where your studs are? That's usually the deal-breaker. If your studs don't co-operate, it's usually up through the cabinet and across the ceiling, which only works if your floor joists run the right way. Nov 22, 2016 at 14:47
  • Thankfully the center of the microwave falls directly between two studs. Nov 22, 2016 at 14:48
From the clarification in the comments, you're lucky!
First, double check that your floor joists are lined up well enough that you can get a 10" duct through the floor where you need it. If a floor joist (or a beam) is massively in the way, you'll need some custom ducting or cancel the job entirely.
I'd cut a generous square at the bottom of the wall so you can cut out the plate in the stud bay. I'd cut slightly generously behind the range hood. (Give a few inches below the hood to allow a connection.)
Make sure you don't have fire blocking/ diagonal bracing/ wiring/ plumbing in the way.
Assemble the hood with a short-way 90 degree elbow. Hang the hood, then push a length of assembled duct up to that elbow from the basement.
If you're lucky again, your floor joists in the basement will let you run the ducting up in them. If the run can be straight out, you'll just need another short-way 90. Otherwise, if you have to zig-zag across the basement, you'll need a couple of long-way 45 degree elbows.
Typical ducting rules apply: use metal tape, screw where necessary, strap to support, and cut slices out of the corners of the duct to nest sections (don't waste your time crimping).
Having just done a very similar job, I can assure you that it's a pain. However, the result will be much better than recirculating.
  • My floor joists line up...again, thankfully. However, about 3 feet from the hole in the floor I have electrical wires running perpendicular through the joists. I'll just have to make a few creative bends to make my way to an outside wall. Thanks for your input...very helpful! If nothing else, just knowing "that it's a pain" makes me feel better. ;) Nov 22, 2016 at 18:44
