I'm installing an IKEA Bjurstra wall-mounted table.
The primary load-bearer is the vertical column, and I've successfully fastened this to a wood stud using 2x #12x2 pan head drill screws:
But the same screws applied to the braces that keep the table flush to the wall, ended up only stripping the dry wall:
So now, though the vertical column is holding up the table just fine, the screws on the braces are loose and hanging out.
  1. What kind of screws should I have used?
  2. Aside from starting over and installing the table at a different height, what can I do to amend this situation?
I am not a DIY-savvy person, so I would prefer ease or convenience over cost-savings. Thank you.
  • Or, did the drywall strip because of how I screwed things in? I used a power drill to first drill a pilot hole, then the power drill again to screw in the screws with moderate but not strong pressure.This actually seemed to have worked for 1 of the 4 screws, but the rest stripped. Nov 22, 2016 at 1:55
  • Next time, try and find the nearest stud - a vertical strip of timber holding up the plasterboard - and screw into that instead, if it is close enough. Otherwise, as noted, use a "readi-driver" or any other type of plasterboard anchor (not just a rawl-plug - they don't have enough holding power for plasterboard)
    – MikeB
    Feb 25, 2020 at 10:28
Agree that you want some dry-wall anchors. Just running a screw into drywall has absolutely no holding power - you need to get something with a very coarse thread, or an anchor that goes through the wall and holds it from the rear side.
Whatever you select, look for the load rating, and divide by 4 for the maximum weight of table and its loading. I prefer Toggler metal connectors (these have a 265lb rating in drywall - and I doubt that the table and contents will weigh more than 66lb).
To install these you need a 1/2" drill bit - so you can reuse the holes you've already drilled for the screws that Bjursta'd out.
I expect you want some kind of wall plug. You would take the table down, install the wall plugs (which generally need a bigger hole than screws so your exiting screwholes shouldn't be an issue) and then screw the shelf to the wall plugs.
Here in the UK I would look at something like this, but i'm not sure how american drywall compares to our plasterboard (also not sure if that one is the right size, I generally judge sizes of such things by eye rather than measurements).
    Here is an American equivalent. The term is wall anchor or screw anchor. There are other types, but I do like these. homedepot.com/p/…
    – DaveM
    Nov 22, 2016 at 2:45
