Can you tell me how i can test to see if a wall is straight for laminate flooring installation?
    You should be starting your install from a chalked line anyway. Or assemble several rows (to create a naturally straight line) and slide them into place against the wall. – isherwood Nov 16 '16 at 16:01
One way to test a wall for straightness is to stretch a string from corner to corner. A good practice when doing this is to space the string out in the corners by the thickness of a board. Then the gap between the string and wall all along can be checked to see how even the wall is. The gap can even be checked with another piece of board that has the same thickness as that used in the corners.
| improve this answer | |
