Can you please tell me what is the most reliable way to install transition strips and molding for laminate flooring on concrete flooring?
Kind regards.
Most of them come with steel channels that you'd fasten with plastic anchors or other concrete fasteners. The moldings press into the channels.
A technique for moldings without channels is to drill 1/2" holes in the concrete, plug them with treated wood dowels, and simply nail down the molding.
  • I have read that it is better to fasten the laminate flooring transition strips and molding with an expandable silicone. Is this correct? – GerritNel Nov 15 '16 at 19:48
  • "Expandable"? Silicone is a very poor adhesive in high traffic situations. It's too soft and tears away readily. You could use a construction adhesive, but that's rather permanent. – isherwood Nov 15 '16 at 19:56
I used construction adhesive like @isherwood mentioned. I will pay for it later when the time comes to remove them, but for now, I am quite pleased with how they have held up (10 years).
