I was trying to install drywall anchors to hold curtain rods. I used a drill bit to make small holes and screwed the drywall anchors into the the holes by hand. A couple went fine on one side of the window. On the other side of the window I tried the same thing but the hole ended up breaking apart and now the drywall anchor just spins and does not hold well. Is there a way I can fix these holes so a new anchor will work or another way to hold the screws in place?
Here are the holes I made and am hoping to fix. (The picture is sideways)
thanks In advance!
