I have a 100 ft run to make. I was going to cut a hole in the existing concrete , lay the cable and pour concrete over top. I am just having troubles figuring out what my different options are for cables. So far I know,
- Teck cable ( I feel it is going to be the most expensive)
Can you please answer me if
I am able to run electrical conduit or regular white walled conduit with some single strands inside?
If I am able to run conduit with BX or Loomex inside?
If I am able to run NMDU ( the loomed with the black outside, weather rated).
It seems to be the embedding in concrete and filling in with concrete that is tripping me up. As well as if you can feed cables like loomex through conduits. I always thought you were only aloud to for a very short run but can not find the code rule saying that.
Thanks everybody.
