There is a center ledger, covered in painted drywall - next to the centered brick chimney(in the center of the house). There's a gap between the ledger and the chimney. Is "Great Stuff" safe to use to insulate this? Isn't there a "Great Stuff" of similar product that is fire retardant? The chimney doesn't get hot, but it can get warm when temperatures get extreme.
    The Great Stuff made for fire retardation is more flammable than the regular Great stuff - which is pretty flammable itself - search youtube for this. I would use roxul.
    – DMoore
    Nov 10, 2016 at 15:26
The clearance for combustible materials to a properly built masonry chimney like you describe would be 0"; no clearance required.
I would use just about anything you want and worry more about getting your chimney inspected and cleaned on a regular basis.
