I ran into an issue while trying to rewire my bathroom's electrical system. I have a small diagram below to illustrate my intentions:
Basically I have two switches, Switch A) is for the hall light, and Switch B)for the bathroom. Alongside the bathroom switch is GFCI outlet that I'd like to keep constant hot. There are two Sheaths of wire cover that come from the ceiling in between the sheetrock. One of them has three wires (white,black,red), and the other is just two wires (white,black). My question is how do I wire this up to work as mentioned? I have spent several hours on it and no luck.
