The plaster ears on old work metal receptacle boxes (see example) each have two holes on the face of them. Is it ok to put screws through these holes to secure the box to baseboard?
In this particular case, I'm replacing an old receptacle and box that's located on the baseboard. The hole for the receptacle box is sized such that the box itself fits through cleanly, but not the plaster ears, which lie flat against the baseboard. I can use a set of those thin metal switch box supports (see example), but it seems the easiest and most secure thing to do would be just to drive 4 screws through the holes in the plaster ears into the baseboard. Is that allowed?
Thanks for your help!
* Image added* (note that I would snap the removable ears off the receptacle so that they don't block the holes on the receptacle box's plaster ears)
