In a vacation home, we installed a new electric hot water heater last year. The vacation home was not used for about 8 months. The breaker to the hot water heater has been off and the main water shut-off valve (into the house) was turned off.
Different acquaintances have different opinions on whether to drain some of the hot water heater before turning on the main water valve as we return to the vacation home.
What will be best to extend the life of the hot water heater? Any other reason to do or not do the draining? And, if draining, what would the proper order/steps in the process be?
Thank you.
  • Has this heater been sitting full of water, or was it never filled to begin with? Nov 5, 2016 at 0:27
  • I believe the service manual should tell you the appropriate start-up procedure. I just installed a tankless (natural gas) that has the start-up and long-term storage procedures in it.
    – Hari
    Feb 7, 2017 at 20:54
-1
First off -- if your tank has been sitting idle eight months while full, there's a good chance that it's produced some hydrogen gas. To fix this, go up to the highest hot water faucet in the house and open it, but do not have any open flames or lit cigarettes present, and do not turn on any lights or appliances where the faucet is. If hydrogen is present, you will hear a hissing noise and/or see bubbles if you take a sample of the hot water with a glass. Keep the faucet open until the hissing stops and hot water flows steadily from the tap.
Second, "draining" a hot water heater is a misnomer -- your goal is to remove sediment from the heater, and that requires some oomph to push the sediment bits out. See this answer by BMitch for his suggestions as to flushing a typical residential tank like yours.
Finally, you may run into problems with stinky rotten egg smells in your hot water even after a flush -- hydrogen sulfide can also be a problem for idle hot water heaters, depending on your water supply and anode chemistry. Spiking the tank with hydrogen peroxide when you bring it back into service is a common, cheap solution to this problem -- a tee piece and valves can be used to provide a place to add it to the heater. There is more documentation on the peroxide fix available from Water Heater Rescue in case you want to try it, by the way. (Another trick for stinky heaters is an aluminum/zinc alloy or powered anode, but that doesn't always work if a heater is left idle for very long periods of time.)
