I have some track lights that run in my upstairs bedroom. A while ago they stopped working, I could flip the switch but there was no light. So I get around to doing some investigating and grab my non-contact meter and there is definitely voltage to each track. Next I take out the multi-meter to test the AC voltage. I was getting 84v AC which is too low, so I am thinking that maybe I have a bad neutral connection or something.
I head down to the basement to start flipping the breakers. I didn't have my entire house mapped at the time so I started turning off one breaker at a time and then running back upstairs to check the voltage with the non-contact meter. Well sure enough I tried them all and never got the power disconnected from the tracks. I then proceeded to turn of one whole side of the breaker box, go and check the voltage, and there is no voltage at the track. I figured I must have made a mistake when checking the 40 individually and proceed to turn the breakers on two at a time so I don't have to run up and down stairs so often. Finally I get power back to the tracks, I go downstairs and turn one of the two breakers off, and find that I still have voltage to the track. I think I have isolated the correct breaker until I turn the isolated one off and the one next to it on. I check the tracks again, and I still have voltage to them.
I can only remove the power if both breakers are closed. Did the two circuits accidentally get wired together? Can anyone else think what the cause of this might be?
    Sure sounds like it...maybe you can post some photos of the situation? – ThreePhaseEel Nov 4 '16 at 22:27
  • "I can only remove the power if both breakers are closed." Do you mean when both breakers are open? When a breaker is in the OFF position, the contacts inside are open. Sorry to nip pick, but it's important to know if the breakers are on or off. – Tester101 Nov 5 '16 at 0:29
    Non-contact meters are notorious for telling you there's voltage present when there is none. You should re-test with a contact meter or test load. – A. I. Breveleri Nov 5 '16 at 4:24
