I am finishing the basement and have already done the plumbing and framing. Now I consider to add cabinet to a room. The cabinet will have a dishwasher so I have to tackle the drain connection. I do not want to add a sink.
The future laundry room is across the wall. The route between the dishwasher to the sink drain/vent pipe is about 2 feet long and involves two 90 degree turns.
What is the simplest connection in this case?
  • It's not at all clear what your concern is. Most dishwashers come with a flex-hose output which will allow you to route it through almost any path. You'll need some sort of Y-connector to hook the hose into the drain (the other side of the Y is from the laundry machine. – Carl Witthoft Oct 31 '16 at 15:39
  • That is the normal way. However since the drywall is not up yet, I prefer having ABS pipe inside the wall, then connecting the hose to the pipe under the cabinet. – cuteCAT Oct 31 '16 at 16:27
  • I agree that I'm not sure what the concern is. A trap does not require a sink, as the clothes washer's standpipe demonstrates.You do also want an air inlet on that drain to ensure against syphoning, but that can be solved exactly as for a sink, or as for the washing machine with a standpipe that the dishwasher's exhaust hose fits loosely into. Just leave off the sink. What's the difficulty? – keshlam Oct 31 '16 at 19:53
