Garage door will not close without holding down the wall button. Only the wall button will close it. Neither wireless remotes work. I have disconnected the safety devises and still have the same issue.
    Some units will not work without the safety sensors. If one had failed you would have the same condition as disconnected. Can you provide the brand / model #. – Ed Beal Oct 30 '16 at 15:34
  • Does it close at all before coming back up? Or does it immediately reverse? Could just need some lubrication – mmathis Oct 30 '16 at 19:37
I have had this happen twice, and it was due to the safety sensors being disconnected. Once I reconnected them and adjusted them to face each other, it fixed it.
I just paid $50 to find out that Liftmaster garage door openers have issues if you place LED bulbs in the opener.
After the tech swapped the bulbs for incandescent, it is working fine.
Also, 1 sensor is green and 1 is amber, and that is normal. Only adjust the green sensor, if you have issues closing without override- per service tech.
The sensor at the bottom of the doorway was loose. I tightened it and now the opener works.
    Hello, and welcome to Home Improvement. This is interesting, but doesn't answer the original question. Please take our tour so you'll know how best to contribute here. – Daniel Griscom Dec 11 '19 at 22:32
