I apologize in advance for some of my incorrect terminology. My father has a 2004 Goodman GMH80904BN gas furnace with a/c. The a/c has functioned properly all summer here in Ohio, we have recently had some cooler nights and when attempting to switch from cool to heat and setting the thermostat well above the current temperature. The thermostat calls for heat, the exhaust/flue fan starts and shortly after the igniter glows and ignites the gas.The fire continues to burn for roughly a minute and then the gas shuts off while the exhaust/flue fan continues to run. Throwing a trouble blink code (4 flashes) which indicates High limit open.
This all makes perfect sense that the high limit would open because at no time does the furnace blower attempt to run. Now the blower does function fine when thermostat is set to cool or off with fan set to on.
To be safe, I replaced the filter. We disconnected the vent pipe/flue to ensure there was no debris.
Checked for continuity at the high limit switch while it was hot/open (no) and again after it had cooled/closed (yes).
Purchased new thermostat to rule out the existing one as faulty. The new stat produced the same symptoms.
I was told the pcb was replaced at the very most 5 years ago along with a new blower motor when furnace was serviced.
Its my understanding that the blower in this furnace is controlled by the pcb and i'm beginning to fear the pcb has failed again. I attempted switching the fan from auto to on while also switching to heat. The blower was on, the vent motor also turned on. Furnace ignited, blower continued to run for about 30 seconds at which the blower the shut off and then after a short period of time the limit switch opened again and everything shut down.
Sorry for the long post, but hopefully my attempt at being through will help someone with the proper knowledge point me in the right direction & we can finally put this problem behind us. Any help is greatly appreciated! God Bless
med. Low
speed on the blower is broken. If the burner runs too long without a blower on, it will overheat.
