The garage door motor has snapped on the gear. When the garage is activated, the motor spins but the gear doesn't turn and so neither does the chain attached to the garage.
Gear
Can I keep the garage door opener and attach a new gear by taking apart the opener?
closed as unclear what you're asking by isherwood, Daniel Griscom, ThreePhaseEel, Tester101 Feb 1 '17 at 15:14
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    Opener repair parts are often available. Search your model number. If not, you should be able to reuse the sprocket and build a replacement assembly using hardware store parts. Did you have a more specific question? – isherwood Oct 26 '16 at 19:16
  • Have you tried removing the bolt holding the gear? If you're in luck, the bolt sheared, and you'll just need to extract it with a screw extractor and replace it with a Grade 5 bolt of the same size. – DrMoishe Pippik Oct 28 '16 at 2:46
The pictured sprocket looks fine to me. You must mean either the internal plastic sprocket or worm gear. They are available for replacement from major brands.
