I am installing a drop ceiling with pot lights as part of remodeling a portion of my basement. Since I am refinishing the entire room (newly framed walls), it seems like I have a catch 22:
- I need to get the electrical rough-in done before I put up drywall (including the wiring to the pot lighting fixtures in the drop-ceiling)
- However, I have always seen drop ceilings installed after the drywall is up, which means I cannot mount the pot lights in the ceiling/wire for them unless I mount the grid (or some portion of it) for the drop ceiling first.
Can I wire up a portion of the grid for the suspended ceiling before drywalling and leave gaps around the edges slightly bigger (~1/8" - e.g. 3/4" gap for 5/8" cement board) than required to insert drywall, or is this a ludicrous suggestion?
Or, is the wiring for pot lights in this situation typically addressed as part of the final inspection? I was not planning on having any additional junction boxes between the panel and the pot lights (all splices to supply multiple lights are supposed to just be inside of the boxes on the pot lights per my submitted plans). Since a portion of the wire run from the breaker panel to the pot lights will be concealed by dry wall for another room (I am finishing the other room at the same time under the same permit) which means the cable would be run from the panel and dangling near where the pot light will eventually be mounted for the rough-in inspection in this case.
I plan on calling my inspector to see what is acceptable, but what is typical practice in this situation?
