I have some solid oak counter tops that I've cut and fitted, and now I'm ready to start finishing them. Right out of the box I noticed some lighter colored, reflective blemishes around the top. They appear randomly across the tops and do not span across multiple boards when they occur.
The tops come "finished" (smooth to maybe 60 grit, with one coat of oil treatment). I plan on sanding them and finishing with 4 coats of Waterlox.
I started with a piece of scrap hoping the marks would go away with sanding, but they haven't yet. Right side is sanded 100/120/150, left side is factory. You can see the marks on the 2nd plank from the right and on the plank center frame.
They reflect light differently from the rest of the board. Note from this angle you can barely see them.
Close up of the mark that has some sanding
Close up of the other mark with the finish from the factory
Will the Waterlox mask or exacerbate these marks? Should I keep sanding? Or should I give up and accept them? I was already strategeic with my cuts and minimized how many and how visible they will be in the kitchen.
Thanks.
