There is a boardwalk through a wooded marsh approximately 250ft long with no line of sight between the ends. Along one side of that boardwalk is an electrical circuit. I need to establish an Ethernet connection between both ends of said boardwalk to transmit video feeds.
If I were to run an Ethernet cable on the opposite side of the boardwalk, might there be appreciable interference from the 120v 60 Hz AC circuit running in parallel for that 250ft with approximately 3ft of separation?
Would Cat 5e vs Cat 6 make much difference?
