We have air vents in all our rooms. We haven't had the heating on yet (it is 20 degrees C in here). We are in a flat of 4; the other units don't have this problem. The window sills run with water if you touch the windows. We tried leaving top window open a bit in each room, had our check for winter done, but still no luck.
    Hello, and welcome to Stack Exchange. Where in the world are you? Is it humid outside? Might there be a source of water inside (e.g. a shower with no vent)? – Daniel Griscom Oct 22 '16 at 11:51
  • Did you experience this previous winters, or is this your first winter in the flat? – littleturtle Oct 22 '16 at 15:29
  • Are you air drying clothing indoors? – Aloysius Defenestrate Oct 23 '16 at 0:44
Showers without venting, a clothes dryer that is not connected to a vent or cooking can all cause the windows to sweat. When my wife is canning even our double pane windows start sweating. A dehumidifier can really help reduce the moisture in the home and Eliminate the window condensation or sweating.
| improve this answer | |
