I found a suspicious looking insect in my kitchen counter top, and I'm wondering if it was a termite. Can anyone who are familiar with termite confirm whether or not the insect in the picture below is a termite? I recall that the length of the insect was about quarter inch (~ 6mm.) enter image description here
I also noticed small white, almost transparent wings floating on top of the pool in my backyard after a couple of rainy days. I guess probably there were a swarm of those insects in my backyard a couple of days ago. Should I worry about any potential termite infestation?
By the way, for anyone who are curious, I live in northern California (Bay area) where termites are common problems.
    It would be helpful if you would edit into your question where in the world you are. Insects vary by county/region. Also has the picture been magnified? How big are these bugs actually?
    – Tyson
    Commented Oct 22, 2016 at 11:23
  • You need to worry if they are inside the house. If they are swarming outside, then typically not a worry (assuming you live in a region where termites are common)
    – DA01
    Commented Oct 25, 2016 at 21:55
  • I updated my question with the region I live in and the size of the insect I observed
    – Jake
    Commented Oct 27, 2016 at 18:20
  • By the way, if it's a termite, is the color black common for termites?
    – Jake
    Commented Oct 27, 2016 at 18:23
It looks like a termite to me, The body is thick all the way back. Ants have a narrow body in the center. Make sure to check around your foundation and look for evidence especially where the dirt is close to the wood. It is possible that a swarm just arrived and that one came into the house through a door or window. With Termites and Carpenter ants it is best to be proactive because they can do a lot of damage in a short period of time. If you are not able to do the inspection under the house it might be worthwhile to hire a pest control company to do the inspection.
