Can SDS drill bits be used with keyed single sleeve drills? If yes, are there any precautions I have to take for ensuring the best result?
Never tried direct as I have a hex to SDS adapter for use in the chuck. – spicetraders Oct 16 '16 at 14:44
Your results will vary by the chuck configuration of your drill. You might get lucky; you might not.
If you chuck the bit in and it's wobbly, try shifting it a tiny amount -- it may work better. Be prepared to tighten the chuck frequently.
If you're drilling a lot of masonry, you might find an upgrade to a real rotary hammer drill (such as a Bosch bulldog) would improve your life a lot.
Almost yes. There are 2 sizes of sds (plus, or max), and also spline drives. Normal bits and roto hammers don't mix. – User95050 Oct 18 '16 at 0:01
