I live in a flat with traditional wood flooring boards. They are pretty much in good condition although some have gaps of a few mm. Anyway we want to fill those gaps probably using Bona Gap Master (I heard it's good) and sawdust + resin. My main worry is to stain the floor with a darker colour and screw it all up. What is the procedure to fill gaps and stain the floor?
  • Are you asking what the correct procedure is if you decide to stain the floor? Or what will look better?
    – Jax
    Oct 14, 2016 at 13:57
  • @Jax I am asking for the procedure to stain the floor
    – Manolete
    Oct 14, 2016 at 14:07
If you sand it you'll eliminate the charming deep grain and rough-sawn artifacts. I wouldn't sand anything but what seems like an injury hazard. I'd also leave the gaps empty. A hard-floor vacuum will keep it clean enough.
To the second question, staining without sanding will give very dramatic color variation in the open grain and saw kerfs. You'll get a nice rustic look. If you prefer a more modern, uniform color, sand it well to an even smoothness after you fill the gaps.
Having said that, I'm voting to close the question as primarily opinion-based.
    I interpreted the intent of the question as "what is the proper procedure" as opposed to "what will look better." I don't know anything about finishing wood floors and might ask the same question. However, as with any trade, I suppose "the proper procedure" could sometimes be a matter of opinion. Perhaps we should give the OP the opportunity to clarify what type of answer is being sought: procedural or opinion?
    – Jax
    Oct 14, 2016 at 13:55
  • Fair enough. I updated my answer to address that point further.
    Oct 14, 2016 at 14:08
  • @isherwood A rustic finish is acceptable and more appropriate for a Victorian flat.
    – Manolete
    Oct 14, 2016 at 14:14
  • I'd love to see a photo when it's done. Consider adding one to your question later.
    Oct 14, 2016 at 14:15
