I was changing a lighting fixture in my hallway. While taking it apart I realized a black and white wire were connected. After 'plugging in' the new fixture and realizing it worked I decided to attach the black and white back together, assuming they were abandoned. Sparks flew and now half my house has no power.
The circuit breaker that blew was reset and is putting out power. But the only thing that has power is an outlet closest to the breaker. Every other outlet and light in that spare hallway basement and master bedroom bedroom is out. enter image description here
    you might have split main breaker and one of two might be tripped. can you edit your question and add a pic of your panel?
    – Skaperen
    Oct 13, 2016 at 4:40
    One could not ask for a better example of the reason why you don't change anything until you know the purpose of every wire. Oct 13, 2016 at 9:23
    Might be time to call in a professional. The large current draw caused by the short-circuit, could have damaged wiring in other parts of the home.
    – Tester101
    Oct 13, 2016 at 10:32
    Sounds like a white being used in a switchloop got mixed up with a true neutral. But the advice of @Tester101 sounds right.
    – bib
    Oct 13, 2016 at 12:03
A ohm meter or continuity tester will help you troubleshoot the wiring. With the power off and the light switch on check each set of black / white wires you are looking for the one that is close to zero ohms or shows continuity, then turn the light switch off and the reading should show close to infinite or no continuity. This wire is the switch leg.
The other 2 cables are your power and the run to another light or outlet. Now if you tie all 3 blacks together that side is done. Mark the white switch leg wire with black tape and connect to the black wire from the light. Connect the 2 remaining white wires together with the white from the light.
Since you have a metal box the ground (bare copper) should be attached to the box It may be better to pigtail the ground if the fixture has a ground wire connect 1 ground to the box then connect the incoming ground and light fixture together. This should get you back up and running.
With a direct short the breakers clear quite fast and don't usually damage the wires. to reset a faulted circuit breaker turn / push it all the way to the off position than back on.
