I have a finished attic with bathroom where there is currently no exhaust. I am thinking of installing an exhaust fan in this space. I have following questions.
1) Can I install a fan that directly vents thought the roof?
2) What kind of exhaust fan do I need? I imagine space is tight between the finished drywall and roof boards.
3) Can this type of installation cause any moisture or ice-dam issues as the part of the insulation will have to be removed to accommodate fan? I live in the northeast.
Thanks!
  • Unfortunately, with the limited information you've given us, we're left to imagine, too. Please update your question with much more information about your roof construction, insulation, etc.
    Oct 12, 2016 at 21:31
  • My apologies for not providing sufficient information. The house has sloping roof with asphalt shingles, and there is fiberglass insulation between the roof rafters. I am no knowledgeable about roofs, but I would think there is a layer of either plywood or some other material under asphalt shingles. Hope that helps.
    – user61270
    Oct 12, 2016 at 22:33
  • Please update your question....
    Oct 12, 2016 at 23:14
  • There's no way you could vent out the side of the house? Going through an insulated roof would be my last choice.
    – topshot
    Oct 13, 2016 at 2:04
  • Unfortunately, there is a bathtub with shower at the exterior wall. I am not sure I could install electrical equipment on that wall.
    – user61270
    Oct 13, 2016 at 16:07
They do make roof vent kits for bathroom fans. The only problem I could see if you get a lot of snow it could get covered but other than that it would be like any standard roof vent.
