In my case, the tank is intact, but the bolt hole in the base cracked off. The bowl itself is fully intact and water-tight. This is the bolt that holds the tank down to the base, not the bolt that holds the base down to the floor.
Broken tank hold-down tab on toilet base
Do I have any options other than replacement? I was considering epoxy, but I'm not sure how long something like that would last.
  • Is this for a toilet? If so replacing the fill valve and supply line would be the best choice. If on LP Gas bottles replacement is an absolute in my book. – Ed Beal Oct 9 '16 at 21:08
  • @Bob, when you say "bolt hole in the base cracked off" do you mean that one of the mounting holes for bolting a toilet bowl to the flange/ring in the floor has broken? Can you post a picture on imgur.com and put a link to the pic in a comment on this post? We will then add the pic to your question. – Jimmy Fix-it Oct 9 '16 at 21:37
  • Since you tagged this 'toilet', I'm gonna go with that. In theory, you could get longer bolts and use a big washer underneath, but on a risk (seriously flooded bathroom)/ reward (saved $150 on a toilet) basis, I'd vote for a new toilet. – Aloysius Defenestrate Oct 9 '16 at 23:53
  • Thanks @JimmyFix-it. I added a link to a couple of pictures on imgur. My description was not very clear! – Bob Oct 10 '16 at 1:28
  • With two-part-epoxy, your options again boil down to @AloysiusDefenestrate's comment above. – iAdjunct Oct 10 '16 at 4:01
