My bathroom sink has a slow persistent leak, and I cant get at the plumbing to fix it, because the pedestal/wall and putty are in the way.
Is this a take the sink out and start again job, or is there an easier solution?
It leaks from where two copper pipes are joined by a fixture, to make it worse, the fixture has some milliput in an attempt to stop the leak, which is hard to remove.
The sink doesn't appear to be attached to the wall.
