I was just over at a place called "Value IT" which used to be called "Value City", and the owners were really creative; they dropped the "C" and the "Y: from the sign to rename the store without buying an entirely new sign. That's just the spirit of that place.
Anyway, aside from this store having wonderfully cheap second hand stuff, it also has walls; and not just any walls; Perforated Hardwood walls, everywhere, so that the landscape of the store can be modified to suite whoever and whatever a vendor may be selling there.
Me being a meta sort of a person, I can't help but wonder where I can get some of these Perforated Hardwood walls for my own place. It would be wonderful to see a mess somewhere, and then organize it on the wall! And if I ever had to move as my capitalist masters frequently dictate; it would be nice to be able to just pack up my wall, and move it to another location...or if as with the vendors at Value IT, my needs would change, I could just take the wall own and re-purpose it.
Now when I was rummaging around "Value IT" as I frequently do, I found an entire stack of the Perforated Hardwood, and it read on the label "Georgia Pacific Clutter Cutter"; which led me to figure out that it was called Perforated Hardwood or "Pegboard". But I was unable to find out what the stuff that fits inside these walls is called. I mean you can't just setup some peg board unless you have a garage with just some wooden rafters behind it to go with it; So in order to make the "walls" there are these vertical metal inserts that you screw the Perforated Hardwood into on both sides in order to form a wall. I suppose it also requires that you have at least two walls facing a 90 degree angle, which makes it seem to me like there are probably at least two kinds of inserts. Anyway the metal inserts for inside the walls were there too, but I couldn't find a label on any of them to find out what they were called.
Does anybody know what those metal inserts inside the walls are called? If they indeed come in more than one variety, let me know that too; Or if they go by one more aliases, just as the pegboard / Perferated Hardwood does. They look pretty cheap and flimsy, but if they do the job, I'm fine with it.
The filmsy metal bits between the walls
More flimsy metal bits between the walls
A pegboard wall in use.
Close up of a pegboard wall in use.
  • Can someone with a bit more rep please tag this as perferated-hardwood, and pegboard?
    – leeand00
    Oct 8, 2016 at 20:11
    pegboard tag added, but couldn't bring myself to 'perferated-hardwood'. (I could fix the misspelling, but I really couldn't see that it's a useful or descriptive tag... if anything, it's perforated hardboard, but that's such an odd term, I don't think there's a mass of people out there waiting to follow.) Oct 8, 2016 at 21:00
  • Are you sure this is hardwood rather than something else with stain/veneer? Photo might help.
    – keshlam
    Oct 9, 2016 at 2:24
    Pegboard is perforated hardboard.
    – Dan D.
    Oct 10, 2016 at 10:41
  • I added some pictures I hope that helps...
    – leeand00
    Oct 10, 2016 at 16:25
4 Answers 4
The metal things in the walls are metal studs, used in place of wooden studs. In other words, these walls are built like any other interior wall, facing material over framing, with appropriate attention to possible fire hazards and so on.
Pegboard is perforated hard board, not hardwood.
Normally you would mount the pegboard either directly to studs, like in a garage, or on top of 1x2 furring strips attached to the studs. If you wanted to get fancy, you could build a frame around it. There are also metal pegboards.
Holy cow just Google peg board hangers like this, and wou will Find lots of options. If it is not a pegboard we will need a photo. A free standing wall is not difficult to build with pegboard on both sides and feet to support. If the peg board is only on 1 side the support legs will need to extend further to prevent it from falling over.
    No...that's not what I want...those are hangers that go in a pegboard once you've already got a pegboard wall. I'm looking to put up a pegboard wall...one that stands on it's own...and then I can put those things in it. But that's after.
    – leeand00
    Oct 9, 2016 at 3:31
The metal pieces holding up the pegboard are simple metal studs. You can find them at any big box hardware store.
As a more approachable alternative, rather than using metal studs, you can use wood studs to frame or float walls and attach the pegboard to those. There are many, many tutorials online that describe different ways to frame a floating wall so I won't post that here. Every situation is different.
If you attach pegboard directly to a finished wall, make sure you use furring strips (just thin pieces of wood) to space the pegboard away from the wall so the metal hangars have space behind them to hang properly.
I've never heard the term "perforated hardwood" used when referring to this pegboard material--for one thing it's certainly not made from hardwood but rather high density fiberboard.
Home Depot has the white-laminated pegboard and Lowes carries the raw-brown colored pegboard.
