my inducer motor runs all the time. what can be wrong I have replaced the thermostat and the controll board and it still does it.
Does the furnace fire up?– Tester101Oct 8, 2016 at 23:16
The model number could help us look it up. Some motors are controlled locally (close to the motor) with a relay some times the relay contacts weld closed this may be the cause but is a guess.– Ed BealOct 9, 2016 at 16:36
Add a comment
