I have this wood polisher a Bosch PSS240A. Issue is the the polishing sheet cannot stick at the front, even after locking it.
Each time I'm starting to polish wood, the sheet is ok as you can see
But after a few seconds of polishing , the sheet is out as the clipping cannot hold the sheet
How come? Is there anything I can do to fix it quickly without needing to go to a repairshop?
Thanks
    The English name for that tool is a sander. I don't know enough about that model to do more than suggest clipping an additional scrap of sandpaper to give it a thicker end to grip. – keshlam Oct 8 '16 at 13:52
  • Hi @keshlam thanks for your feedback. I went to a repairshop and they said it was due to a broken coil spring. They gave me one address, saying it is the best around for this kind of tool. – Andy K Oct 8 '16 at 14:14
I went to a repairshop , they said it was due to a broken coil spring.
Quite cheap to fix rather than buying a new wood sander
