I am installing base cabinets in my basement. The flooring will be a floating laminate, so I can't set the cabinets directly on the flooring. There was a similar question How do I install cabinets on a floating hardwood floor?, but it didn't answer how so install the cabinets on the concrete.
From what I've seen so far, it seems like there should be some sort of shim/spacer system, but I haven't really seen in more detail what this would be. Would I use something like 5/4 PT boards and create a box and set the cabinets on this?
